summaryrefslogtreecommitdiff
path: root/testsuites/libtests/dl06/dl06-o2.h (follow)
AgeCommit message (Collapse)Author
2018-04-12testsuites/dl06: Add a test for RAP format.Chris Johns
This test loads a RAP format file that contains calls that are not in the kernel and linked from libm. It uses and test rtems-ld. Update #2769
