#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
