Use the test state configuration instead.
Update #3818.
Update #3533.
Update #3382
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
of this patch set.
This involved adding a new variable record to the capture buffer
and modifing the trace method to read those records.
This prevents infinite test runs on SMP due to the recursive interrupt
lock acquire.
