Add a simplified path evaluation function IMFS_eval_path_devfs() for a
device only IMFS configuration.
The code size can be further reduced by the application if it disables
the support for legacy IO drivers via:
#define CONFIGURE_IMFS_DISABLE_MKNOD
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES.
Update #3894.
Update #3898.
Update #3894.
Update #3894.
The CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK value is validated by
<rtems/confdefs/libio.h>. Changing this value during runtime could lead
to memory corruption.
Update #3894.
Update #3894.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #3894.
Update #3053.
Update #3894.
Update #3894.
Update #3894.
Remove IMFS_NODE_FLAG_NAME_ALLOCATED and instead replace the node
control in rename operations. This avoids a special case in the general
node destruction which pulled in free().
Update #3894.
In uniprocessor configurations, use compile-time constants for
rtems_scheduler_get_processor_maximum() and
rtems_scheduler_get_processor(). This helps compilers and static
analyzers to deduce that some loop bodies are only executed once and
some conditional statements have a fixed outcome (may improve code
generation and reduce false positives).
In SMP configurations, directly provide the internal implementation for
performance reasons.
The use of CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER does not define
anything, so remove the <rtems/btimer.h> include.
Update #3875.
Update #3881.
Update #3881.
This function is used to perform a full check of the device tree. Allow
it to be excluded if all assumptions are enabled.
Signed-off-by: Simon Glass <sjg@chromium.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200220214557.176528-9-sjg@chromium.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Add a way to remove this check and the reordering code, which is
unnecessary if the dtb is known to be correctly ordered.
Message-Id: <20200220214557.176528-8-sjg@chromium.org>
Allow enabling FDT_ASSUME_LATEST to disable version checks.
Message-Id: <20200220214557.176528-7-sjg@chromium.org>
Allow enabling FDT_ASSUME_NO_ROLLBACK to disable rolling back after a
failed operation.
Message-Id: <20200220214557.176528-6-sjg@chromium.org>
Allow enabling ASSUME_VALID_INPUT to disable sanity checks on the device
tree and the parameters to libfdt. This assumption covers that cases where
the problem could be with either.
Message-Id: <20200220214557.176528-5-sjg@chromium.org>
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Message-Id: <20200220214557.176528-4-sjg@chromium.org>
Add a new ASSUME_MASK option, which allows for some control over the
checks used in libfdt. With all assumptions enabled, libfdt assumes that
the input data and parameters are all correct and that internal errors
cannot happen.
By default no assumptions are made and all checks are enabled.
Message-Id: <20200220214557.176528-3-sjg@chromium.org>
There does not seem to be a strong reason to inline this function. Also
we are about to add some extra code to it which will increase its size.
Move it into fdt.c and use a simple declaration in libfdt.h
Message-Id: <20200220214557.176528-2-sjg@chromium.org>
This function returns an int32_t, however the prototype in
libfdt_internal.h shows it returning an int. We haven't caught this before
because they're the same type on nearly all platforms this gets built on.
Apparently it's not the case on FreeRTOS, so someone hit this mismatch
building for that platform.
Reported-by: dharani kumar <dharanikumarsrvn@gmail.com>
Including libfdt.h in a C++ project fails during compilation with recent
version of GCC or Clang.
This simple example:
extern "C" {
#include <libfdt.h>
int main(void) { return 0; }
leads to the following errors with GCC 9.1.0:
/usr/include/libfdt.h: In function ‘void fdt32_st(void*, uint32_t)’:
/usr/include/libfdt.h:139:16: error: invalid conversion from ‘void*’ to ‘uint8_t*’ {aka ‘unsigned char*’} [-fpermissive]
139 | uint8_t *bp = property;
| void*
/usr/include/libfdt.h: In function ‘void fdt64_st(void*, uint64_t)’:
/usr/include/libfdt.h:163:16: error: invalid conversion from ‘void*’ to ‘uint8_t*’ {aka ‘unsigned char*’} [-fpermissive]
163 | uint8_t *bp = property;
| void*
This commit adds an explicit cast to uint8_t* to fix this issue.
Signed-off-by: Luc Michel <luc.michel@greensocs.com>
Message-Id: <20190910104824.1321594-1-luc.michel@greensocs.com>
c12b2b0c20eb "libfdt: fdt_address_cells() and fdt_size_cells()" introduced
a bug as it consolidated code between the helpers for getting
#address-cells and #size-cells. Specifically #size-cells is allowed to
be 0, and is frequently found so in practice for /cpus. IEEE1275 only
requires implementations to handle 1..4 for #address-cells, although one
could make a case for #address-cells == #size-cells == 0 being used to
represent a bridge with a single port.
While we're there, it's not totally obvious that the existing implicit
cast of a u32 to int will give the correct results according to strict C,
although it does work in practice. Straighten that up to cast only after
we've made our range checks.
Reported-by: yonghuhaige via https://github.com/dgibson/dtc/issues/28
In libfdt we often sanity test fdt_totalsize(fdt) fairly early, then
trust it (but *only* that header field) for the remainder of our work.
However, Coverity gets confused by this - it sees the byteswap in
fdt32_ld() and assumes that means it is coming from an untrusted source
everytime, resulting in many tainted data warnings.
Most of these end up with logic in fdt_get_string() as the unsafe
destination for this tainted data, so let's tweak the logic there to make
it clearer to Coverity that this is ok.
We add a sanity test on fdt_totalsize() to fdt_probe_ro_(). Because the
interface allows bare ints to be used for offsets, we already have the
assumption that totalsize must be 31-bits or less (2GiB would be a
ludicrously large fdt). This makes this more explicit.
We also make fdt_probe_ro() return the size for convenience, and change the
logic in fdt_get_string() to keep it in a local so that Coverity can see
that it has already been bounds-checked.
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20190620211944.9378-3-robh@kernel.org>
Searching for duplicate names scales O(n^2) with the number of names
added to a fdt, which can cause a noticable slowdown with larger device
trees and very slow CPU cores.
Add FDT_CREATE_FLAG_NO_NAME_DEDUP that allow the caller to trade fdt size
for speed in the creation process.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Message-Id: <20190509094122.834-4-npiggin@gmail.com>
There is a need to be able to specify some options when building an FDT
with the SW interface. This can be accomplished with minimal changes by
storing intermediate data in the fdt header itself, in fields that are
not otherwise needed during the creation process and can be set by
fdt_finish().
The fdt.magic field is already used exactly this way, as a state to
check with callers that the FDT has been created but not yet finished.
fdt.version and fdt.last_comp_version are used to make room for more
intermediate state. These are adjacent and unused during the building
process. last_comp_version is not yet used for intermediate state, but
it is zeroed and treated as used, so as to allow future growth easily.
A new interface, fdt_create_with_flags() is added, which takes 32-bit
flag value to control creation.
Message-Id: <20190509094122.834-3-npiggin@gmail.com>
If fdt_add_property or fdt_property_placeholder fail after allocating
a string for the name, they return without freeing that string. This
does not change the structure of the tree, but in very specific cases
it could lead to undesirable space consumption.
Fix this by rolling back the string allocation in this situation.
Message-Id: <20190509094122.834-2-npiggin@gmail.com>
It's now a trivial wrapper around fdt_find_max_phandle() so we might as
well inline it. We also remove it from the versioning linker script.
Theoretically, that's a breaking ABI change except that we haven't yet
released a version with it exposed in the shared object, so we can get
away with it.
The new fdt_generate_phandle() function can be used to generate a new,
unused phandle given a specific device tree blob. The implementation is
somewhat naive in that it simply walks the entire device tree to find
the highest phandle value and then returns a phandle value one higher
than that. A more clever implementation might try to find holes in the
current set of phandle values and fill them. But this implementation is
relatively simple and works reliably.
Also add a test that validates that phandles generated by this new API
are indeed unique.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Message-Id: <20190326153302.17109-3-thierry.reding@gmail.com>
The fdt_get_max_phandle() function has some shortcomings. On one hand
it returns just a uint32_t which means to check for the "negative"
error code a caller has to explicitly check against the error code
(uint32_t)-1. In addition, the -1 is the only error code that can be
returned, so a caller cannot tell the difference between the various
failures.
Fix this by adding a new fdt_find_max_phandle() function that returns an
error code on failure and 0 on success, just like other APIs, and stores
the maximum phandle value in an output argument on success.
This also refactors fdt_get_max_phandle() to use the new function. Add a
note pointing out that the new fdt_find_max_phandle() function should be
preferred over fdt_get_max_phandle().
Message-Id: <20190326153302.17109-1-thierry.reding@gmail.com>
[dwg: Reword for some inaccuracies in the commit message]
This function will append an address range property using parent node's
"#address-cells" and "#size-cells" properties.
It will be used in implementing kdump with kexec_file_load system call
at linux kernel for arm64 once it is merged into kernel tree.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Message-Id: <20190327061552.17170-2-takahiro.akashi@linaro.org>
[dwg: Correct a SEGV error in the testcase]
This reverts commit 54ea41c22415cb0e283d22faf71202051c89400c.
are indeed unique.
Message-Id: <20190320151003.28941-1-thierry.reding@gmail.com>
The actual error is FDT_ERR_NOTFOUND, not FDT_ERR_NOT_FOUND.
Fixes: d29126c90acb0d70 ("libfdt: Add iterator over properties")
Fixes: 902d0f0953d0074b ("libfdt: Add a subnodes iterator macro")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The second parameter of fdt_getprop_by_offset() is called "offset", not
"ffset".
6dcb8ba4 "libfdt: Add helpers for accessing unaligned words" introduced
the fdt32_ld() and fdt64_ld() helpers for loading values from the FDT blob
which might not be naturally aligned. This matters for ARM, where
attempting a plain unaligned load will often cause an exception.
However, it seems the memcpy() we used here was surprisingly expensive,
making libfdt nearly 6x slower on at least some ARM platforms.
This patch takes an alternative approach, using a bunch of 1-byte loads
and shifts to implement the helpers.
According to the device tree specification, the default value for
#size-cells is 1, but fdt_size_cells() was returning 2 if this property
was not present.
This patch also makes fdt_address_cells() and fdt_size_cells() conform
to the behaviour documented in libfdt.h. The defaults are only returned
if fdt_getprop() returns -FDT_ERR_NOTFOUND, otherwise the actual error
is returned.
Signed-off-by: John Clarke <johnc@kirriwa.net>
In uniprocessor and SMP configurations, the context switch extensions
were called during _Thread_Do_dispatch():
void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
Thread_Control *executing;
executing = cpu_self->executing;
do {
Thread_Control *heir;
heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
_User_extensions_Thread_switch( executing, heir );
_Context_Switch( &executing->Registers, &heir->Registers );
} while ( cpu_self->dispatch_necessary );
In uniprocessor configurations, this is fine and the context switch
extensions are called for all thread switches except the very first
thread switch to the initialization thread. However, in SMP
configurations, the context switch may be invalidated and updated in the
low-level _Context_Switch() routine. See:
https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html#thread-dispatch-details
In case such an update happens, a thread will execute on the processor
which was not seen in the previous call of the context switch
extensions. This can confuse for example event record consumers which
use events generated by a context switch extension.
Fixing this is not straight forward. The context switch extensions call
must move after the low-level context switch. The problem here is that
we may end up in _Thread_Handler(). Adding the context switch
extensions call to _Thread_Handler() covers now also the thread switch
to the initialization thread. We also have to save the last executing
thread (ancestor) of the processor. Registers or the stack cannot be
used for this purpose. We have to add it to the per-processor
information. Existing extensions may be affected, since now context
switch extensions use the stack of the heir thread. The stack checker
is affected by this.
Calling the thread switch extensions in the low-level context switch is
difficult since at this point an intermediate stack is used which is
only large enough to enable servicing of interrupts.
Update #3885.
Update #3835.
This define may be used by application configurations for the
CONFIGURE_APPLICATION_EXTRA_DRIVERS definition.
Update #3875.
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Change licence of <rtems/confdefs.h> to BSD-2-Clause according to file
history.
Update #3053.
Close #3875.
Update #3053.
Update #3875.
Update #3053.
Update #3875.
Update #3053.
Update #3875.
