summaryrefslogtreecommitdiff
path: root/cpukit/score/src/userextaddset.c (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2020-02-28score: Fix context switch extensions (SMP)Sebastian Huber
In uniprocessor and SMP configurations, the context switch extensions were called during _Thread_Do_dispatch(): void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level ) { Thread_Control *executing; executing = cpu_self->executing; ... do { Thread_Control *heir; heir = _Thread_Get_heir_and_make_it_executing( cpu_self ); ... _User_extensions_Thread_switch( executing, heir ); ... _Context_Switch( &executing->Registers, &heir->Registers ); ... } while ( cpu_self->dispatch_necessary ); ... } In uniprocessor configurations, this is fine and the context switch extensions are called for all thread switches except the very first thread switch to the initialization thread. However, in SMP configurations, the context switch may be invalidated and updated in the low-level _Context_Switch() routine. See: https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html#thread-dispatch-details In case such an update happens, a thread will execute on the processor which was not seen in the previous call of the context switch extensions. This can confuse for example event record consumers which use events generated by a context switch extension. Fixing this is not straight forward. The context switch extensions call must move after the low-level context switch. The problem here is that we may end up in _Thread_Handler(). Adding the context switch extensions call to _Thread_Handler() covers now also the thread switch to the initialization thread. We also have to save the last executing thread (ancestor) of the processor. Registers or the stack cannot be used for this purpose. We have to add it to the per-processor information. Existing extensions may be affected, since now context switch extensions use the stack of the heir thread. The stack checker is affected by this. Calling the thread switch extensions in the low-level context switch is difficult since at this point an intermediate stack is used which is only large enough to enable servicing of interrupts. Update #3885.
2019-04-12score: Use an ISR lock for Per_CPU_Control::LockSebastian Huber
The use of a hand crafted lock for Per_CPU_Control::Lock was necessary at some point in the SMP support development, but it is no longer justified.
2019-04-04doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber
Update #3706
2016-08-01score: Fix for RTEMS_DEBUG.Chris Johns
2016-04-18score: Use chain iterator for user extensionsSebastian Huber
Add a lock and use a chain iterator for safe iteration during concurrent user extension addition and removal. Ensure that dynamically added thread delete and fatal extensions are called in reverse order. Update #2555. Update #2692.
2016-03-22score: Fix for RTEMS_DEBUGSebastian Huber
The rtems_extension_create() no longer uses the Giant lock. Ensure that we call _User_extensions_Add_set() only in the right context. Update #2555.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2013-08-09score: Add and use _Per_CPU_Acquire_all().Sebastian Huber
Add and use _Per_CPU_Release_all(). The context switch user extensions are invoked in _Thread_Dispatch(). This change is necessary to avoid the giant lock in _Thread_Dispatch().
2012-11-22score: Add and use <rtems/score/userextimpl.h>Sebastian Huber
This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2009-09-252009-09-25 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/extensioncreate.c, sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h, score/src/userextthreaddelete.c, score/src/userext.c, score/src/userextthreadcreate.c, score/src/userextremoveset.c, score/src/userextthreadbegin.c, score/src/userextaddset.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c, score/src/userextthreadrestart.c: Documentation. The types User_extensions_routine and rtems_extension are now deprecated. Removed unused types User_extensions_thread_post_switch_extension and rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set() in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in _User_extensions_Add_set_with_table(). * score/src/userextaddapiset.c: Removed file. * score/Makefile.am: Update.
2007-05-092007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c, sapi/Makefile.am, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/userext.h, score/src/chain.c, score/src/userext.c: Switch to newlib reentrancy extension being installed in the initial set instead of using rtems_extension_create. While implementing this, noticed that user extensions and chain code had multiple functions in a single file which is not desirable in the SuperCore and API portions of RTEMS, so split these into multiple files with one function per file. Also noticed that some of user extension code was inlined for no particular reason so moved that to C bodies. Split executive shutdown from initialization since not every application shuts down. Moved __fini call to executive shutdown to be more symmetrical with where it is called at startup. * sapi/src/exshutdown.c, score/src/chainappend.c, score/src/chainextract.c, score/src/chainget.c, score/src/chaininsert.c, score/src/userextaddapiset.c, score/src/userextaddset.c, score/src/userextremoveset.c, score/src/userextthreadbegin.c, score/src/userextthreadcreate.c, score/src/userextthreaddelete.c, score/src/userextthreadrestart.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c: New files. * score/inline/rtems/score/userext.inl: Removed.
