#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3706
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Split up the potential thread priority change in the scheduler
release/cancel job operation. Protect the rate monotonic period state
with a dedicated SMP lock. This avoids a race condition during
_Rate_monotonic_Timeout() while _Rate_monotonic_Cancel() is called on
another processor.
Do not use a deadline value of zero to indicate a job cancellation. Use
a dedicated scheduler operation for this.
Pass the deadline in watchdog ticks to the scheduler.
Update #2173.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Rename _Scheduler_priority_Release_job() into
_Scheduler_default_Release_job().
