2019-04-04 | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | |
Update #3706 | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2011-12-06 | 2011-12-06 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | |
* score/src/heapiterate.c, score/src/pheapiterate.c: New files. * score/Makefile.am: Reflect changes above. * score/include/rtems/score/heap.h: Declare _Heap_Iterate() and define Heap_Block_visitor. * score/include/rtems/score/protectedheap.h: Declare _Protected_heap_Iterate(). * score/src/heapgetinfo.c: Use _Heap_Iterate(). |
