summaryrefslogtreecommitdiff
path: root/cpukit/score/src/corerwlockrelease.c (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2019-04-04doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber
Update #3706
2017-10-05posix: Implement self-contained POSIX rwlocksSebastian Huber
POSIX rwlocks are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3115.
2016-05-26score: Add Status_Control for all APIsSebastian Huber
Unify the status codes of the Classic and POSIX API to use the new enum Status_Control. This eliminates the Thread_Control::Wait::timeout_code field and the timeout parameter of _Thread_queue_Enqueue_critical() and _MPCI_Send_request_packet(). It gets rid of the status code translation tables and instead uses simple bit operations to get the status for a particular API. This enables translation of status code constants at compile time. Add _Thread_Wait_get_status() to avoid direct access of thread internal data structures.
2016-05-25score: Move thread queue MP callout to contextSebastian Huber
Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers.
2016-05-25score: Get rid of mp_id parameterSebastian Huber
Get rid of the mp_id parameter used for some thread queue methods. Use THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
2016-04-22score: Avoid Giant lock for CORE rwlockSebastian Huber
Update #2555.
2016-04-21score: Rename _CORE_RWLock_Obtain()Sebastian Huber
Rename _CORE_RWLock_Obtain_for_reading() into _CORE_RWLock_Seize_for_reading(). Rename _CORE_RWLock_Obtain_for_writing() into _CORE_RWLock_Seize_for_writing(). Rename _CORE_RWLock_Release() into _CORE_RWLock_Surrender(). This avoids confusion with the ISR lock acquire and release.
2016-04-06score: Rework MP thread queue callout supportSebastian Huber
The thread queue implementation was heavily reworked to support SMP. This broke the multiprocessing support of the thread queues. This is fixed by this patch. A thread proxy is unblocked due to three reasons 1) timeout, 2) request satisfaction, and 3) extraction. In case 1) no MPCI message must be sent. This is ensured via the _Thread_queue_MP_callout_do_nothing() callout set during _Thread_MP_Allocate_proxy(). In case 2) and 3) an MPCI message must be sent. In case we interrupt the blocking operation during _Thread_queue_Enqueue_critical(), then this message must be sent by the blocking thread. For this the new fields Thread_Proxy_control::thread_queue_callout and Thread_Proxy_control::thread_queue_id are used. Delete the individual API MP callout types and use Thread_queue_MP_callout throughout. This type is only defined in multiprocessing configurations. Prefix the multiprocessing parameters with mp_ to ease code review. Multiprocessing specific parameters are optional due to use of a similar macro pattern. There is no overhead for non-multiprocessing configurations.
2016-03-29score: Remove Thread_queue_Queue::operations fieldSebastian Huber
Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects.
2015-05-19score: _Thread_queue_Extract()Sebastian Huber
Remove thread queue parameter from _Thread_queue_Extract() since the current thread queue is stored in the thread control block.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2013-07-26score: Create threadq implementation headerSebastian Huber
Move implementation specific parts of tqdata.h, threadq.h and threadq.inl into new header file threadqimpl.h. The threadq.h contains now only the application visible API. Delete tqdata.h.
2013-07-26score: Create states implementation headerSebastian Huber
Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API.
2013-07-22score: Avoid direct usage of _Thread_ExecutingSebastian Huber
Pass the executing thread as a function parameter. Obtain the executing thread inside a thread dispatch critical section to avoid problems on SMP.
2013-07-22score: Create rwlock implementation headerSebastian Huber
Move implementation specific parts of corerwlock.h and corerwlock.inl into new header file corerwlockimpl.h. The corerwlock.h contains now only the application visible API.
2012-12-01score misc: Score misc: Clean up Doxygen #10 (GCI 2012)Christopher Kerl
This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/7983216
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-07-242011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
2009-11-29Whitespace removal.Ralf Corsepius
2008-01-292008-01-29 Jennifer Averett <jennifer.averett@OARcorp.com>Jennifer Averett
* score/src/corerwlockrelease.c, score/src/coresemseize.c: Changed switch statements to if statements.
2007-11-272007-11-27 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey
* posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, rtems/include/rtems/rtems/barrier.h, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c: Fixed several implementation errors.
2007-05-222007-05-22 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* score/src/corerwlockrelease.c: Do not dereference NULL.
2006-12-042006-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* posix/src/prwlockunlock.c, rtems/Makefile.am, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c: Complete implementation of barrier as the rest of the test code is now implemented. Also add blocking code to rwlock.
2006-09-25 * score/Makefile.am, score/preinstall.am,Joel Sherrill
score/include/rtems/score/coresem.h, score/include/rtems/score/object.h, score/include/rtems/score/states.h, score/inline/rtems/score/coresem.inl: Add SuperCore Barriers, SpinLocks and a partial implementation of RWLocks. * score/include/rtems/score/corebarrier.h, score/include/rtems/score/corerwlock.h, score/include/rtems/score/corespinlock.h, score/inline/rtems/score/corebarrier.inl, score/inline/rtems/score/corerwlock.inl, score/inline/rtems/score/corespinlock.inl, score/macros/rtems/score/corebarrier.inl, score/macros/rtems/score/corerwlock.inl, score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c: New files.
