2019-04-04 | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | |
Update #3706 | |||
2019-03-14 | Remove superfluous <rtems/system.h> includes | Sebastian Huber | |
2019-03-12 | coremsgseize.c: Fix spelling error | Joel Sherrill | |
2017-10-24 | score: Move thread queue timeout handling | Sebastian Huber | |
Update #3117. Update #3182. | |||
2017-10-24 | score: Rename function threadq support function | Sebastian Huber | |
Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into _Thread_queue_Context_set_enqueue_do_nothing_extra(). More _Thread_queue_Context_set_enqueue_*() functions will follow. Update #3117. Update #3182. | |||
2017-01-31 | score: Add _Thread_queue_Object_name | Sebastian Huber | |
Add the special thread queue name _Thread_queue_Object_name to mark thread queues embedded in an object with identifier. Using the special thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for this purpose since the thread wait information and thread state are protected by different SMP locks in separate critical sections. Remove STATES_THREAD_QUEUE_WITH_IDENTIFIER. Add and use _Thread_queue_Object_initialize(). Update #2858. | |||
2017-01-11 | score: Add STATES_THREAD_QUEUE_WITH_IDENTIFIER | Sebastian Huber | |
Add thread state bit to identify thread queues that are embedded in an object with identifier. | |||
2016-11-24 | score: Optimize _Thread_queue_Enqueue() | Sebastian Huber | |
Move thread state for _Thread_queue_Enqueue() to the thread queue context. This reduces the parameter count of _Thread_queue_Enqueue() from five to four (ARM for example has only four function parameter registers). Since the thread state is used after several function calls inside _Thread_queue_Enqueue() this parameter was saved on the stack previously. | |||
2016-11-23 | score: Rename _Thread_queue_Enqueue_critical() | Sebastian Huber | |
Delete unused _Thread_queue_Enqueue() and rename _Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue(). | |||
2016-11-23 | score: Add thread queue enqueue callout | Sebastian Huber | |
Replace the expected thread dispatch disable level with a thread queue enqueue callout. This enables the use of _Thread_Dispatch_direct() in the thread queue enqueue procedure. This avoids impossible exection paths, e.g. Per_CPU_Control::dispatch_necessary is always true. | |||
2016-07-25 | cpukit: Add and use Watchdog_Discipline. | Gedare Bloom | |
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE, or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline of WATCHDOG_NO_TIMEOUT. updates #2732 | |||
2016-05-30 | score: _CORE_mutex_Check_dispatch_for_seize() | Sebastian Huber | |
Move the safety check performed by _CORE_mutex_Check_dispatch_for_seize() out of the performance critical path and generalize it. Blocking on a thread queue with an unexpected thread dispatch disabled level is illegal in all system states. Add the expected thread dispatch disable level (which may be 1 or 2 depending on the operation) to Thread_queue_Context and use it in _Thread_queue_Enqueue_critical(). | |||
2016-05-26 | score: Add Status_Control for all APIs | Sebastian Huber | |
Unify the status codes of the Classic and POSIX API to use the new enum Status_Control. This eliminates the Thread_Control::Wait::timeout_code field and the timeout parameter of _Thread_queue_Enqueue_critical() and _MPCI_Send_request_packet(). It gets rid of the status code translation tables and instead uses simple bit operations to get the status for a particular API. This enables translation of status code constants at compile time. Add _Thread_Wait_get_status() to avoid direct access of thread internal data structures. | |||
2016-05-25 | score: Move thread queue MP callout to context | Sebastian Huber | |
Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers. | |||
2016-05-25 | score: Get rid of mp_id parameter | Sebastian Huber | |
Get rid of the mp_id parameter used for some thread queue methods. Use THREAD_QUEUE_QUEUE_TO_OBJECT() instead. | |||
2016-05-24 | score: _CORE_message_queue_Seize() | Sebastian Huber | |
Delete unused parameter. | |||
2016-05-02 | score: _CORE_message_queue_Insert_message() | Sebastian Huber | |
Move common code into _CORE_message_queue_Insert_message(). | |||
2016-05-02 | score: _CORE_message_queue_Set_message_priority() | Sebastian Huber | |
Remove _CORE_message_queue_Set_message_priority() and set the priority in _CORE_message_queue_Insert_message(). | |||
2016-05-02 | score: _CORE_message_queue_Seize() | Sebastian Huber | |
Move lock acquire to caller of _CORE_message_queue_Seize() to allow state checks during receive operations under lock protection. | |||
2016-04-06 | score: Rework MP thread queue callout support | Sebastian Huber | |
The thread queue implementation was heavily reworked to support SMP. This broke the multiprocessing support of the thread queues. This is fixed by this patch. A thread proxy is unblocked due to three reasons 1) timeout, 2) request satisfaction, and 3) extraction. In case 1) no MPCI message must be sent. This is ensured via the _Thread_queue_MP_callout_do_nothing() callout set during _Thread_MP_Allocate_proxy(). In case 2) and 3) an MPCI message must be sent. In case we interrupt the blocking operation during _Thread_queue_Enqueue_critical(), then this message must be sent by the blocking thread. For this the new fields Thread_Proxy_control::thread_queue_callout and Thread_Proxy_control::thread_queue_id are used. Delete the individual API MP callout types and use Thread_queue_MP_callout throughout. This type is only defined in multiprocessing configurations. Prefix the multiprocessing parameters with mp_ to ease code review. Multiprocessing specific parameters are optional due to use of a similar macro pattern. There is no overhead for non-multiprocessing configurations. | |||
2016-04-06 | score: Delete Thread_Wait_information::id | Sebastian Huber | |
This field was only by the monitor in non-multiprocessing configurations. Add new field Thread_Wait_information::remote_id in multiprocessing configurations and use it for the remote procedure call thread queue. Add _Thread_Wait_get_id() to obtain the object identifier for debug and system information tools. Ensure the object layout via static asserts. Add test cases to sptests/spthreadq01. | |||
2016-03-29 | score: Remove Thread_queue_Queue::operations field | Sebastian Huber | |
Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects. | |||
2015-07-23 | score: Introduce Thread_queue_Queue | Sebastian Huber | |
Separate the thread queue heads and lock from the operations. This enables the support for light weight objects which only support one queuing discipline. | |||
2015-05-19 | score: Fine grained locking for message queues | Sebastian Huber | |
Aggregate several critical sections into a bigger one. Sending and receiving messages is now protected by an ISR lock. Thread dispatching is only disabled in case a blocking operation is necessary. The message copy procedure is done inside the critical section (interrupts disabled). Thus this change may have a negative impact on the interrupt latency in case very large messages are transferred. Update #2273. | |||
2015-05-19 | score: Delete Thread_queue_Control::timeout_status | Sebastian Huber | |
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory usage. | |||
2015-05-19 | score: Add Thread_queue_Control::Lock | Sebastian Huber | |
Move the complete thread queue enqueue procedure into _Thread_queue_Enqueue_critical(). It is possible to use the thread queue lock to protect state of the object embedding the thread queue. This enables per object fine grained locking in the future. Delete _Thread_queue_Enter_critical_section(). Update #2273. | |||
2015-04-23 | score: Delete Thread_queue_Control::state | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-08-23 | score: _Thread_queue_Enqueue_with_handler() | Sebastian Huber | |
Add thread parameter to _Thread_queue_Enqueue_with_handler() to avoid access to global _Thread_Executing. | |||
2013-07-26 | score: Create object implementation header | Sebastian Huber | |
Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | |||
2013-07-26 | score: Create states implementation header | Sebastian Huber | |
Move implementation specific parts of states.h and states.inl into new header file statesimpl.h. The states.h contains now only the application visible API. | |||
2013-07-22 | score: Avoid direct usage of _Thread_Executing | Sebastian Huber | |
Pass the executing thread as a function parameter. Obtain the executing thread inside a thread dispatch critical section to avoid problems on SMP. | |||
2013-07-22 | score: Create message queue implementation header | Sebastian Huber | |
Move implementation specific parts of coremsg.h and coremsg.inl into new header file coremsgimpl.h. The coremsg.h contains now only the application visible API. | |||
2012-11-29 | score misc: Score misc: Clean up Doxygen #5 | Alex Ivanov | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2011-07-24 | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | |||
2009-11-29 | Whitespace removal. | Ralf Corsepius | |
2009-09-13 | 2009-09-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* score/inline/rtems/score/coremsg.inl, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c: Add wrappers for accessing message priority. Since these are empty when priority-based message queues are disabled, this eliminates some of the conditionals. | |||
2009-09-12 | 2009-09-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* score/src/coremsgseize.c: Fix typo. | |||
2009-09-11 | 2009-09-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* score/include/rtems/score/coremsg.h, score/inline/rtems/score/coremsg.inl, score/src/coremsg.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/objectnametoidstring.c: Disable the Core Message Queue features of notification, priority messages, and blocking sends when no API requires them. | |||
2008-12-22 | Eliminate TRUE/FALSE. | Ralf Corsepius | |
2008-09-05 | 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/corerwlock.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemseize.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/threadblockingoperationcancel.c, score/src/threadqenqueue.c: Remove unnecessary include of mpci.h. | |||
2008-09-04 | Convert to "bool". | Ralf Corsepius | |
2008-08-05 | 2008-08-04 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | |
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c: Changed option set type to rtems_option. * score/src/objectgetinfo.c: Check return value of _Objects_API_maximum_class(). * libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h, rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h, score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h, score/inline/rtems/score/coremsg.inl, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c: Removed parameters of _Message_queue_Allocate(). Changed option set type to rtems_option. Changed type of maximum message and packet size to size_t. Changed the input buffer type for message send functions to "const void *". Changed the pointer to the second return argument in the thread wait information to a union. This union can contain a pointer to an immutable or a mutable object. This is somewhat fragile. An alternative would be to add a third pointer for immutable objects, but this would increase the structure size. | |||
2008-01-07 | 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* score/inline/rtems/score/isr.inl: Fix spacing. * score/src/apimutexallocate.c: Fix spacing. * score/src/coremsgseize.c: Check for message pending instead of message pending count to avoid dead code from inlined chain routine. It checks if the chain is empty so is redundant to count == 0. | |||
2007-05-11 | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* score/src/coremsgseize.c: A blocking sender's message size was pulled out of the wrong field in the Wait information structure. * score/src/objectallocate.c: With the new optional manager support, we only stub out the initialization. This makes it possible to attempt to create an object with the information structure only initialized with all zeros. This ensures we return an error cleanly in this case. | |||
2007-02-06 | Use size_t for sizes. | Ralf Corsepius | |
2005-01-27 | Include config.h. | Ralf Corsepius | |
2004-04-18 | Remove stray white spaces. | Ralf Corsepius | |
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | |
