2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2016-04-18 | sapi: Avoid Giant lock for extensions | Sebastian Huber | |
Extension create and delete is protected by the object allocator lock. Update #2555. | |||
2014-03-31 | score: PR2152: Use allocator mutex for objects | Sebastian Huber | |
Use allocator mutex for objects allocate/free. This prevents that the thread dispatch latency depends on the workspace/heap fragmentation. | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-07-26 | score: Create object implementation header | Sebastian Huber | |
Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | |||
2013-07-23 | sapi: Create extension implementation header | Sebastian Huber | |
Move implementation specific parts of extension.h and extension.inl into new header file extensionimpl.h. The extension.h contains now only the application visible API. | |||
2013-06-07 | score: Add and use _Objects_Put() | Sebastian Huber | |
Add and use _Objects_Put_without_thread_dispatch(). These two functions pair with the _Objects_Get() function. This helps to introduce object specific SMP locks to avoid lock contention. | |||
2013-04-23 | sapi: Fix warnings | Sebastian Huber | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2009-11-29 | Whitespace removal. | Ralf Corsepius | |
2009-09-25 | 2009-09-25 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | |
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/extensioncreate.c, sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h, score/src/userextthreaddelete.c, score/src/userext.c, score/src/userextthreadcreate.c, score/src/userextremoveset.c, score/src/userextthreadbegin.c, score/src/userextaddset.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c, score/src/userextthreadrestart.c: Documentation. The types User_extensions_routine and rtems_extension are now deprecated. Removed unused types User_extensions_thread_post_switch_extension and rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set() in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in _User_extensions_Add_set_with_table(). * score/src/userextaddapiset.c: Removed file. * score/Makefile.am: Update. | |||
2007-12-19 | 2007-12-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c: Extension Manager clean up. Update object id switches to new pattern. Catch some NULL parameter errors. | |||
2007-10-26 | 2007-10-26 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c, itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c, itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignalsupp.c, posix/src/condwaitsupp.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/mqueueclose.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c, posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspindestroy.c, posix/src/pspinlock.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c, rtems/src/barrierdelete.c, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventsend.c, rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/signalsend.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskissuspended.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/timercancel.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c, score/include/rtems/score/object.h, score/src/corerwlocktimeout.c, score/src/mpci.c, score/src/objectgetnameasstring.c, score/src/threaddelayended.c, score/src/threadqtimeout.c: When multiprocessing is disabled, do not even allow the constant OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results in the generation of binary code which can NOT be reached. | |||
2005-01-28 | 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c: Include config.h. | |||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* include/confdefs.h, include/rtems/config.h, include/rtems/extension.h, include/rtems/fatal.h, include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h, include/rtems/sptables.h, include/rtems/sptables.h.in, inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c, src/exinit.c, src/extension.c, src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c, src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license changed. | |||
2002-03-15 | 2001-03-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above. |
