2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2016-11-02 | score: Introduce Thread_Scheduler_control::home | Sebastian Huber | |
Replace Thread_Scheduler_control::control and Thread_Scheduler_control::own_control with new Thread_Scheduler_control::home. Update #2556. | |||
2016-06-22 | posix: _POSIX_Mutex_Default_attributes | Sebastian Huber | |
Make _POSIX_Mutex_Default_attributes constant and independent of the scheduler instance. Use INT_MAX to indicate the default ceiling priority. | |||
2016-06-14 | posix: sched_get_priority_max() | Sebastian Huber | |
Enable for all configurations since it pulls in no additional dependencies. Return value of the scheduler instance of the executing thread. | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-07-22 | posix: Create priority implementation header | Sebastian Huber | |
Move implementation specific parts of priority.h and priority.inl into new header file priorityimpl.h. Remove priority.h since there is no application visible API. | |||
2013-01-10 | cpukit/posix: Doxygen group is POSIXAPI | Joel Sherrill | |
2012-12-18 | posix: Doxygen Enhancement Task #11 | Ayush Awasthi | |
http://www.google-melange.com/gci/task/view/google/gci2012/7987221 | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2007-12-13 | 2007-12-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* posix/Makefile.am, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c, posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c, posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c, posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c, posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c, posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split files into one function per file. * posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c, posix/src/aio_read.c, posix/src/aio_return.c, posix/src/aio_suspend.c, posix/src/aio_write.c, posix/src/lio_listio.c, posix/src/sched_getparam.c, posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c, posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c, posix/src/sched_setparam.c, posix/src/sched_setscheduler.c, posix/src/sched_yield.c: New files. * posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed. |
