#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
The original CPU_COPY() support of Newlib <sys/cpuset.h> had the
parameters in the wrong order. This is fixed in Newlib since
2017-05-22.
Update #3023.
This patch adds the following methods:
+ pthread_attr_get_affinity_np
+ pthread_attr_set_affinity_np
