2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2015-10-26 | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-01-10 | cpukit/posix: Doxygen group is POSIXAPI | Joel Sherrill | |
2012-12-15 | posix: Doxygen Enhancement Task #1 | Alex Ivanov | |
http://www.google-melange.com/gci/task/view/google/gci2012/7987220 | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2011-12-05 | 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* posix/src/pthreadatfork.c: Include <pthread.h> (Missing prototypes). | |||
2009-01-02 | Add __attribute__((unused)) to unused function args. | Ralf Corsepius | |
2007-12-13 | 2007-12-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* posix/Makefile.am, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c, posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c, posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c, posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c, posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c, posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split files into one function per file. * posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c, posix/src/aio_read.c, posix/src/aio_return.c, posix/src/aio_suspend.c, posix/src/aio_write.c, posix/src/lio_listio.c, posix/src/sched_getparam.c, posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c, posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c, posix/src/sched_setparam.c, posix/src/sched_setscheduler.c, posix/src/sched_yield.c: New files. * posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed. | |||
2004-04-16 | Remove stray white spaces. | Ralf Corsepius | |
2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | |||
1999-01-25 | Split most of POSIX Threads Manager into multiple files. | Joel Sherrill | |
1998-09-25 | Added ENOSYS stubs for a number of process routines. | Joel Sherrill | |
