summaryrefslogtreecommitdiff
path: root/cpukit/posix/src/pause.c (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2013-01-10cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill
2012-12-15posix: Doxygen Enhancement Task #2Alex Ivanov
http://www.google-melange.com/gci/task/view/google/gci2012/7988213
2012-12-05posix: Add and use <rtems/posix/psignalimpl.h>Sebastian Huber
This file contains the parts of <rtems/posix/psignal.h> that are only necessary for the POSIX API implementation.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2004-04-15Remove stray white spaces.Ralf Corsepius
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
2001-01-242001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
1999-11-17Updated copyright notice.Joel Sherrill
1999-01-31Split psignal.c into many more files. This reduced the amount ofJoel Sherrill
object code that has to be loaded just for initializing the signal manager.
