2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2019-03-14 | Remove superfluous <rtems/system.h> includes | Sebastian Huber | |
2016-04-12 | posix: Rename killinfo() | Sebastian Huber | |
Apparently killinfo() is not defined by POSIX, glibc or FreeBSD. Rename killinfo() to _POSIX_signals_Send() to cleary mark it as an internal function. | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-07-22 | posix: Create pthread implementation header | Sebastian Huber | |
Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API. | |||
2013-01-10 | cpukit/posix: Doxygen group is POSIXAPI | Joel Sherrill | |
2012-12-15 | posix: Doxygen Enhancement Task #8 | Mathew Kallada | |
http://www.google-melange.com/gci/task/view/google/gci2012/8003213 | |||
2012-12-05 | posix: Add and use <rtems/posix/psignalimpl.h> | Sebastian Huber | |
This file contains the parts of <rtems/posix/psignal.h> that are only necessary for the POSIX API implementation. | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2007-12-20 | 2007-12-20 Jennifer Averett <jennifer.averett@OARcorp.com> | Jennifer Averett | |
* posix/Makefile.am, posix/src/kill.c, posix/src/killinfo.c: Split file and resolved copyright information. * posix/src/kill_r.c: New file. | |||
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | |
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed. | |||
2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | |
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | |||
1999-11-17 | Updated copyright notice. | Joel Sherrill | |
1999-01-31 | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | |
object code that has to be loaded just for initializing the signal manager. |
