summaryrefslogtreecommitdiff
path: root/cpukit/libtrace/record (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2020-03-18record: Add rtems_record_dump()Sebastian Huber
Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib(). Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options. Update #3904.
2020-02-04Use RTEMS_SYSINIT_ORDER_LAST_BUT_5Sebastian Huber
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST to allow applications and support functions to place system initialization handlers behind the standard handlers. Update #3838.
2019-10-02Revert "record: Add wrappers for malloc() functions"Sebastian Huber
It was accidentally committed. This reverts commit a314544a278f1533ae001f742d7fe24fcee253e6.
2019-10-01record: Add wrappers for malloc() functionsSebastian Huber
Introduce new library librtemsrecordwrap.a which contains wrappers for operating system functions which produce entry/exit events. The wrappers can be selected during link time via the GNU ld --wrap option. Update #3665.
2019-09-02record: Add system eventsSebastian Huber
Update #3665.
2019-08-30record: Add system eventsSebastian Huber
Add system events for memory allocation/free. Update #3665.
Add system events to identify the target system. Add system events to transfer blocks of memory and register sets. Update #3665.
2019-08-30record: Simplify configurationSebastian Huber
Update #3665.
2019-08-30record: Introduce _Record_Drain()Sebastian Huber
This allows its use in crash dump procedures. Update #3665.
2019-08-29record: Add more system eventsSebastian Huber
Reduce the system dependencies to allow tracing of very low level functions, for example the interrupt disable/enable. Introduce general purpose RTEMS_RECORD_CALLER and RTEMS_RECORD_LINE events. Update #3665.
2019-08-28record: Introduce <rtems/recordserver.h>Sebastian Huber
This helps to get rid of the <rtems/rtems/tasks.h> dependency in <rtems/record.h>. Update #3665.
2019-08-28record: Use BSS section instead of per-CPU dataSebastian Huber
The .rtemsrwset section is used for the per-CPU data. This section has loadable content. Place the ring buffers in the BSS section to avoid large executable image sizes. Not using the per-CPU data makes it possible to initialize the record support earlier. Update #3665.
2019-08-27record: Add data size to clientSebastian Huber
This is necessary to get the thread names properly on 32-bit and 64-bit targets. Update #3665.
2019-08-27record: Fix thread names on 64-bit targetsSebastian Huber
Also fixes the thread names on signed char targets. Update #3665.
2019-08-26record: Improve overflow handlingSebastian Huber
Signal the accumulated item overflow count with the time of the first new item.
2019-08-26record: Fix off by one errorSebastian Huber
2019-08-17record: Pass bintime to client handlersSebastian Huber
This is a minor optimization.
2019-08-17record: Simplify client visit()Sebastian Huber
2019-08-17record: Remove superfluous castSebastian Huber
2019-08-17record: Increase client robustnessSebastian Huber
Do nothing after errors.
2019-08-17record: Improve overflow handlingSebastian Huber
In case of a ring buffer overflow, the rtems_record_drain() will push the complete ring buffer content to the client. While the items are processed by the client, new items may overwrite some items being processed. The overwritten items can be detected in the following iteration once the next tail/head information is pushed to the client.
2019-08-16record: Detect also large overflowsSebastian Huber
2019-08-16record: Simplify rtems_record_client_contextSebastian Huber
2019-08-06record: Change thread name encodingSebastian Huber
This scheme is easier to decode.
2019-07-30record: Add support for thread namesSebastian Huber
2019-04-09rtems: Add rtems_scheduler_get_processor_maximum()Sebastian Huber
Add rtems_scheduler_get_processor_maximum() as a replacement for rtems_get_processor_count(). The rtems_get_processor_count() is a bit orphaned. Adopt it by the Scheduler Manager. The count is also misleading, since the processor set may have gaps and the actual count of online processors may be less than the value returned by rtems_get_processor_count(). Update #3732.
2019-03-12record: Add more system eventsSebastian Huber
Update #3665.
2019-03-12record: Add system call entry/exit eventsSebastian Huber
This corresponds to the Linux syscall_entry_* and syscall_exit_* events. Update #3665.
2019-03-12record: Rename internal per-CPU eventsSebastian Huber
Update #3665.
2019-01-30record: Add enum value for each eventSebastian Huber
Update #3665.
2019-01-29Add low level event recording supportSebastian Huber
Add low level event recording infrastructure for system and user defined events. The infrastructure is able to record high frequency events such as * SMP lock acquire/release, * interrupt entry/exit, * thread switches, * UMA zone allocate/free, and * Ethernet packet input/output, etc. It allows post-mortem analysis in fatal error handlers, e.g. the last events are in the record buffer, the newest event overwrites the oldest event. It is possible to detect record buffer overflows for consumers that expect a continuous stream of events, e.g. to display the system state in real-time. The implementation supports high-end SMP machines (more than 1GHz processor frequency, more than four processors). Add a new API instead. The implementation uses per-processor data structures and no atomic read-modify-write operations. It is uses per-processor ring buffers to record the events. The CPU counter is used to get the time of events. It is combined with periodic uptime events to synchronize it with CLOCK_REALTIME. The existing capture engine tries to solve this problem also, but its performance is not good enough for high-end production systems. The main issues are the variable-size buffers and the use of SMP locks for synchronization. To fix this, the API would change significantly. Update #3665.
