2019-02-28 | Remove explicit file names from @file | Sebastian Huber | |
This makes the @file documentation independent of the actual file name. Update #3707. | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2009-11-30 | Whitespace removal. | Ralf Corsepius | |
2008-12-11 | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | |
2005-05-09 | New. | Ralf Corsepius | |
2005-02-03 | New. | Ralf Corsepius | |
