2018-09-10 | network: Use kernel/user space header files | Sebastian Huber | |
Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375. | |||
2016-07-01 | net: Fix byte order issue for getnameinfo() | Sebastian Huber | |
2016-06-28 | libnetworking: Add minimal getnameinfo() | Christian Mauderer | |
This implementation just falls back to giving a string representation of the IP. It supports IPv4 only. Add test for getnameinfo(). |
