#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3859
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Do not use the rtems_error() function since this function pulls in
exit() and abort(). The abort() function pulls in raise() which pulls
in the whole POSIX signals support. This change saves about 16KiB of
text/rodata on ARM Thumb-2 systems.
Close #3720.
The region_information_block typedef as no corresponding API. It has no
proper namespace prefix. A user can do nothing with it.
Close #3591.
Update #3375.
Update #3530.
Update #3533.
Do not discard a user provided task name in rtems_shell_init_env().
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3260.
Prepare for header file move to common include directory.
Update #3254.
Update #2132.
Update #2133.
Update #3082.
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3096.
Update #2833.
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
Update #2803.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
Update #2723.
of this patch set.
Works also with previous Newlib versions.
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
