Move the is SMP enabled configuration constant out of the
configuration table.
Since this was the last configuration constant in
rtems_configuration_table, remove this type.
Update #3875.
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Move variant, discipline, and global information to flags stored in a
node pointer of active semaphores.
Update #3833.
Add and use _Thread_Get_unmapped_real_priority().
Use functions instead of macros. Add missing
rtems_configuration_get_maximum_*() functions.
Update #3621.
The RTEMS_USE_16_BIT_OBJECT define is not set by an RTEMS port. Remove
support for 16-bit object identifiers. If someone really wants to use
RTEMS on a 16-bit target, then it is better to use self-contained
objects instead of playing around with object identifier optimizations.
Update #3603.
Update #3598.
Update #3598.
Update #3598.
Update #3598.
Update #3587.
Update #3589.
Update #2514.
Update #3530.
Update #3533.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Prepare for header file move to common include directory.
Update #3254.
Display the scheduler name instead of the current CPU in the "task"
shell command. The current CPU could be misleading in case locking
protocols are involved. The "cpuuse" command can be used to obtain the
current CPU.
Closes #2997.
Print wait object identifier only if it exists.
Update #2858.
Add the special thread queue name _Thread_queue_Object_name to mark
thread queues embedded in an object with identifier. Using the special
thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for
this purpose since the thread wait information and thread state are
protected by different SMP locks in separate critical sections. Remove
STATES_THREAD_QUEUE_WITH_IDENTIFIER.
Add and use _Thread_queue_Object_initialize().
Update #2858.
Update #2858.
Replace STATES_DELAYING with STATES_WAITING_FOR_TIME.
There is no need for separate timeout thread states. The
Thread_Control::Timer::header and Watchdog_Control::cpu members can be
used to figure out the kind of timeout.
Add thread state bit to identify thread queues that are embedded in an
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Update #2556.
Avoid direct access to thread internal data fields.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Move MrsP semaphore operations to a less prominent location. Fix field
name.
Provide dedicated seize and surrender methods for inherit priority
mutexes. This eliminates CORE_mutex_Attributes.
Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid
the run-time evaluation of attributes to figure out how a particular
mutex methods should behave. Start with the no protocol variants. This
eliminates the CORE_MUTEX_DISCIPLINES_FIFO and
CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
Rework _Thread_Restart_other() to use _Thread_Change_life_locked().
Cope with concurrent change requests by means of a pending request
counter.
Update #2555.
Update #2626.
Split _Thread_Close() into _Thread_Join() and _Thread_Cancel() to
prepare for a re-use in pthread_join() and pthread_cancel().
Update #2555.
Update #2626.
Update #2555.
Remove unused location parameter.
Use Heap_Statistics::used_blocks instead.
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
