summaryrefslogtreecommitdiff
path: root/cpukit/libgnat (follow)
AgeCommit message (Collapse)Author
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2019-03-14Remove superfluous <rtems/system.h> includesSebastian Huber
2018-10-10build: Merge libgnat/Makefile.amSebastian Huber
2018-04-04build: Remove EXTRA_DISTSebastian Huber
A "make dist" is not supported. So, it makes no sense to have pure "make dist" related stuff in the Makefile.am.
2015-10-30ada: Add missing includeJan Sommer
Include stackimpl.h otherwise PTHREAD_MINIMUM_STACK_SIZE cannot be evaluated.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2013-08-08PR766: Delete __RTEMS_INSIDE__Sebastian Huber
2013-07-22posix: Create pthread implementation headerSebastian Huber
Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius
2012-02-01Remove all .cvsignore files.Joel Sherrill
2010-03-272010-03-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* libgnat/ada_intrsupp.c, telnetd/check_passwd.c, telnetd/des.c, telnetd/genpw.c: Add include of config.h
2009-11-30Whitespace removal.Ralf Corsepius
2008-12-162008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* libgnat/adasupp.c: Add helper method so Ada binding does not reference _TOD_Microseconds_per_tick.
2008-06-30Use LIBGNAT.Ralf Corsepius
2007-12-122007-12-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill
* libgnat/Makefile.am, wrapup/Makefile.am: Another attempt at the automake variables.
* libgnat/Makefile.am: Handle POSIX being disabled correctly.
2007-12-122007-12-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am: Move Ada support code that is untestable from the Standard RTEMS Test Suite into its own directory. All code in score, posix, rtems, and sapi should be testable by the Standard RTEMS Test Suites. It was buried under POSIX before so this should be a clearer location anyway. * libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c, libgnat/adasupp.c: New files. * posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
