#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Prepare for header file move to common include directory.
Update #3254.
Drop superfluous <stdlib.h> include from <rtems/diskdevs.h> since this
leads to conflicts with the latest Newlib in case this header file is
used in the FreeBSD kernel space, e.g. for USB mass storage support.
This is for the RFS file system. The statvfs call reports 1 block free
when the file system is full because it does not account for the superblock
in its calculation of free blocks.
This is a simple fix that adjusts the number of blocks reported to account
for the superblock. We may want to wait for a more complete solution such
as locating the superblock in each group.
Change rtems-rfs to rtems_rfs
o Removed RTEMS_LIBIO_PERMS_SEARCH.
o Renamed RTEMS_LIBIO_PERMS_READ in RTEMS_FS_PERMS_READ.
o Renamed RTEMS_LIBIO_PERMS_WRITE in RTEMS_FS_PERMS_WRITE.
o Renamed RTEMS_LIBIO_PERMS_EXEC in RTEMS_FS_PERMS_EXEC.
o Renamed RTEMS_LIBIO_FOLLOW_HARD_LINK in RTEMS_FS_FOLLOW_HARD_LINK.
o Renamed RTEMS_LIBIO_FOLLOW_SYM_LINK in RTEMS_FS_FOLLOW_SYM_LINK.
o Renamed RTEMS_LIBIO_MAKE in RTEMS_FS_MAKE.
o Renamed RTEMS_LIBIO_EXCLUSIVE in RTEMS_FS_EXCLUSIVE.
o Renamed RTEMS_LIBIO_ACCEPT_RESIDUAL_DELIMITERS in
RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS.
o Renamed RTEMS_LIBIO_REJECT_TERMINAL_DOT in
RTEMS_FS_REJECT_TERMINAL_DOT.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
* libfs/src/rfs/rtems-rfs-trace.c,
libfs/src/rfs/rtems-rfs-trace.h: Add inode-delete.
* libfs/src/rfs/rtems-rfs-shell.c: Fix formatting.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Use ssize_t. Fix spelling.
* libfs/src/rfs/rtems-rfs-block.c: Fix rtems_rfs_block_get_bpos to
return the position correctly. A bpos does not have any special
processing. Do no reset the buffer handle when shrinking
indirectly.
* libfs/src/rfs/rtems-rfs-inode.c: Add trace.
* libfs/src/rfs/rtems-rfs-format.c: Fix comments.
* libfs/src/rfs/rtems-rfs-group.c: Limit the inodes to the blocks
in a group so the accounting works.
* libfs/src/rfs/rtems-rfs-dir.c: PR 1705. Fix handling the offsets
when deleting an entry.
* libfs/src/rfs/rtems-rfs-buffer.h: Remove
rtems_rfs_buffer_handle_reset. It is not needed and dangerous.
PR 1587/filesystem
Coverity Id 35
* libfs/src/rfs/rtems-rfs-shell.c: Address possible NULL dereference.
* libfs/src/rfs/rtems-rfs-shell.c: Various 64bit fixes.
PR 1556/cpukit
* libfs/src/rfs/rtems-rfs-shell.c: Remove rtems_rfs_shell_cmd_t.
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-shell.c: Fix for PR1502. Clean up problems
on 16bit targets.
libfs/src/nfsclient/src/cexphelp.c,
libfs/src/nfsclient/src/dirutils.c,
libfs/src/nfsclient/src/nfs.modini.c,
libfs/src/nfsclient/src/nfsTest.c,
libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/rpcio.modini.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-block.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let
files receive configure defines.
* libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-file.c,
libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-shell.c: Fix printf format warning. Primarily
for size_t.
* libfs/src/rfs/rtems-rfs-block.c: Reset a buffer handle after
moving down an indirection level.
* libfs/src/rfs/rtems-rfs-dir.c: Move directory entry validation
into a macro and use the macro. Fix the range check on the ino so
all inodes can be used.
* libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system.h:: Add a version number to
the superblock. Use RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-file.c: Fix the size offset on partial
block lengths. Set the size in the file handle on a truncate to
0.
* libfs/src/rfs/rtems-rfs-format.c: Add a version number to
the superblock. Use RTEMS_RFS_INODE_SIZE. A better set of defaults
for small disks.
* libfs/src/rfs/rtems-rfs-inode.c: Use RTEMS_RFS_INODE_SIZE. Free
the allocated inode if it cannot be opened.
* libfs/src/rfs/rtems-rfs-inode.h: Add RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-rtems-file.c: Move some of the iop
acceses inside the fs lock.
* libfs/src/rfs/rtems-rfs-shell.c: Use RTEMS_RFS_INODE_SIZE.
* libfs/src/rfs/rtems-rfs-dir.c: Fix printf format warning for a
64bit off_t.
* libfs/src/rfs/rtems-rfs-file-system.h: Add a macro to get the
file system flags.
* libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h: Add rtems_rfs_group_usage.
* libfs/src/rfs/rtems-rfs-rtems.c: Fill in all the fields in the
statvfs struct.
* libfs/src/rfs/rtems-rfs-shell.c: Use rtems_rfs_group_usage.
* libblock/src/diskdevs.c: Create the devices as block devices.
* libmisc/shell/main_debugrfs.c, libmisc/shell/main_mkrfs.c,
libmisc/shell/main_mount_rfs.c: New.
* libmisc/shell/main_msdosfmt.c: Change the command to mkdos and
alias the old name.
* libmisc/shell/shellconfig.h, libmisc/Makefile.am: Add RFS
support.
* libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-shell.h: Move the format command code into
the shell file.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
