summaryrefslogtreecommitdiff
path: root/cpukit/libfs/src/rfs/rtems-rfs-block.c (unfollow)
AgeCommit message (Collapse)Author
2020-04-28doxygen: Switch @brief and @ingroupSebastian Huber
2020-04-16Canonicalize config.h includeSebastian Huber
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2013-07-23Include missing <string.h>Sebastian Huber
2013-01-10rfs: Doxygen group cannot have a dash in itJoel Sherrill
Change rtems-rfs to rtems_rfs
2012-12-18libfs: Doxygen Enhancement Task #2Alex Ivanov
http://www.google-melange.com/gci/task/view/google/gci2012/8032207
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-11-06Remove stray whitespaces.Ralf Corsepius
2010-10-112010-10-11 Chris Johns <chrisj@rtems.org>Chris Johns
* libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: Add inode-delete. * libfs/src/rfs/rtems-rfs-shell.c: Fix formatting. * libfs/src/rfs/rtems-rfs-rtems-dir.c: Use ssize_t. Fix spelling. * libfs/src/rfs/rtems-rfs-block.c: Fix rtems_rfs_block_get_bpos to return the position correctly. A bpos does not have any special processing. Do no reset the buffer handle when shrinking indirectly. * libfs/src/rfs/rtems-rfs-inode.c: Add trace. * libfs/src/rfs/rtems-rfs-format.c: Fix comments. * libfs/src/rfs/rtems-rfs-group.c: Limit the inodes to the blocks in a group so the accounting works. * libfs/src/rfs/rtems-rfs-dir.c: PR 1705. Fix handling the offsets when deleting an entry. * libfs/src/rfs/rtems-rfs-buffer.h: Remove rtems_rfs_buffer_handle_reset. It is not needed and dangerous.
2010-06-172010-06-18 Chris Johns <chrisj@rtems.org>Chris Johns
* libfs/src/rfs/rtems-rfs-file-block.c: Clean up uint64_t maths.
2010-06-152010-06-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c, libnetworking/nfs/bootp_subr.c: Misc. 64bit-compatibility fixes.
2010-03-272010-03-27 Chris Johns <chrisj@rtems.org>Chris Johns
libfs/src/nfsclient/src/cexphelp.c, libfs/src/nfsclient/src/dirutils.c, libfs/src/nfsclient/src/nfs.modini.c, libfs/src/nfsclient/src/nfsTest.c, libfs/src/nfsclient/src/rpcio.c, libfs/src/nfsclient/src/rpcio.modini.c, libfs/src/nfsclient/src/sock_mbuf.c, libfs/src/nfsclient/src/xdr_mbuf.c, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-trace.c: Add HAVE_CONFIG_H support to let files receive configure defines.
2010-03-222010-03-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-shell.c: Fix printf format warning. Primarily for size_t.
2010-02-26010-02-26 Chris Johns <chrisj@rtems.org>Chris Johns
* libfs/src/rfs/rtems-rfs-block.c: Reset a buffer handle after moving down an indirection level. * libfs/src/rfs/rtems-rfs-dir.c: Move directory entry validation into a macro and use the macro. Fix the range check on the ino so all inodes can be used. * libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system.h:: Add a version number to the superblock. Use RTEMS_RFS_INODE_SIZE. * libfs/src/rfs/rtems-rfs-file.c: Fix the size offset on partial block lengths. Set the size in the file handle on a truncate to 0. * libfs/src/rfs/rtems-rfs-format.c: Add a version number to the superblock. Use RTEMS_RFS_INODE_SIZE. A better set of defaults for small disks. * libfs/src/rfs/rtems-rfs-inode.c: Use RTEMS_RFS_INODE_SIZE. Free the allocated inode if it cannot be opened. * libfs/src/rfs/rtems-rfs-inode.h: Add RTEMS_RFS_INODE_SIZE. * libfs/src/rfs/rtems-rfs-rtems-file.c: Move some of the iop acceses inside the fs lock. * libfs/src/rfs/rtems-rfs-shell.c: Use RTEMS_RFS_INODE_SIZE.
2010-02-182010-02-18 Chris Johns <chrisj@rtems.org>Chris Johns
* libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir-hash.h, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.h, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h, libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: New. * Makefile.am, preinstall.am, libfs/Makefile.am, wrapup/Makefile.am: Updated with the RFS support. * libfs/README: Updated after 10 years. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk-driver.c: Updated to the new error reporting in libblock. * libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing the size in long mode. * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP to the forever behaviour of 4.9 with the ability to call BOOTP and control the process if required.
