2020-04-16 | Canonicalize config.h include | Sebastian Huber | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||
2018-04-12 | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | |
2018-02-07 | libdl: Fix potential overwrite of dest buffer | Sebastian Huber | |
Update #2843. | |||
2018-02-07 | libdl: Use self-contained mutex for RAP | Sebastian Huber | |
Update #2843. | |||
2016-06-22 | Move printer initialization to separate header | Sebastian Huber | |
The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>. | |||
2015-03-20 | Replace www.rtems.com with www.rtems.org | Sebastian Huber | |
2014-10-31 | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | |
This is a merge of the RTL project. |
