summaryrefslogtreecommitdiff
path: root/cpukit/libcsupport/src/unlink.c (follow)
AgeCommit message (Collapse)Author
2015-10-26basdefs.h: Add and use RTEMS_UNUSEDSebastian Huber
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns
2012-12-11libcsupport: Doxygen enhancement GCI task #4Alex Ivanov
http://www.google-melange.com/gci/task/view/google/gci2012/8009205
2012-10-07Filesystem: Rename functionSebastian Huber
Rename rtems_filesystem_location_is_root() into rtems_filesystem_location_is_instance_root() to distinguish this from the file system root directory of the current task environment.
2012-10-07Filesystem: Reject removal of root nodesSebastian Huber
Reject the removal of file system instance root nodes in rmdir() and unlink() and return the EBUSY error status. File system instances can be removed with unmount(). Remove root node special cases in IMFS, DOSFS, and RFS.
2012-05-15Filesystem: Move operations to mount table entrySebastian Huber
The scope of the file system operations is the file system instance. The scope of the file system node handlers is the file location. The benefit of moving the operations to the mount table entry is a size reduction of the file location (rtems_filesystem_location_info_t). The code size is slightly increased due to additional load instructions. Restructure rtems_filesystem_mount_table_entry_t to improve cache efficiency.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-03-13Filesystem: Rename definesSebastian Huber
o Removed RTEMS_LIBIO_PERMS_SEARCH. o Renamed RTEMS_LIBIO_PERMS_READ in RTEMS_FS_PERMS_READ. o Renamed RTEMS_LIBIO_PERMS_WRITE in RTEMS_FS_PERMS_WRITE. o Renamed RTEMS_LIBIO_PERMS_EXEC in RTEMS_FS_PERMS_EXEC. o Renamed RTEMS_LIBIO_FOLLOW_HARD_LINK in RTEMS_FS_FOLLOW_HARD_LINK. o Renamed RTEMS_LIBIO_FOLLOW_SYM_LINK in RTEMS_FS_FOLLOW_SYM_LINK. o Renamed RTEMS_LIBIO_MAKE in RTEMS_FS_MAKE. o Renamed RTEMS_LIBIO_EXCLUSIVE in RTEMS_FS_EXCLUSIVE. o Renamed RTEMS_LIBIO_ACCEPT_RESIDUAL_DELIMITERS in RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS. o Renamed RTEMS_LIBIO_REJECT_TERMINAL_DOT in RTEMS_FS_REJECT_TERMINAL_DOT.
2012-03-13Filesystem: Reference counting for locationsSebastian Huber
o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
2010-07-012010-07-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* libcsupport/src/_rename_r.c, libcsupport/src/getdents.c, libcsupport/src/unlink.c, libcsupport/src/utime.c, libcsupport/src/writev.c: Remove remaining checks for missing handlers.
2010-07-012010-07-01 Jennifer Averett <Jennifer.Averett@OARcorp.com>Jennifer Averett
* libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/close.c, libcsupport/src/eval.c, libcsupport/src/fchdir.c, libcsupport/src/fchmod.c, libcsupport/src/fchown.c, libcsupport/src/fcntl.c, libcsupport/src/fdatasync.c, libcsupport/src/freenode.c, libcsupport/src/fstat.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/ioctl.c, libcsupport/src/link.c, libcsupport/src/lseek.c, libcsupport/src/mknod.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/read.c, libcsupport/src/readlink.c, libcsupport/src/readv.c, libcsupport/src/rmdir.c, libcsupport/src/stat.c, libcsupport/src/statvfs.c, libcsupport/src/symlink.c, libcsupport/src/unlink.c, libcsupport/src/unmount.c, libcsupport/src/write.c: Removed filesystem checks for NULL methods checks from the main posix rountines. These are now required to have at a miminum default routines in the tables.
2010-02-162010-02-16 Chris Johns <chrisj@rtems.org>Chris Johns
* libcsupport/src/open.c: Tighten the open handler check. 2010-02-16 Sebastian Huber <sebastian.huber@embedded-brains.de> * libcsupport/src/rmdir.c, libcsupport/src/unlink.c: Free the allocated pathloc.
2009-11-29Whitespace removal.Ralf Corsepius
2009-09-15Add __attribute__((unused)) to function arguments.Ralf Corsepius
2009-06-122009-06-12 Chris Johns <chrisj@rtems.org>Chris Johns
* libblock/src/bdbuf.c: Update comments. * libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the device from the rdev field of the stat buf. * libcsupport/include/rtems/libio.h: Add a path length to evalpath handler. Add parent locations to rmmod and unlink handlers. * libcsupport/include/rtems/libio_.h: Add a path length to rtems_filesystem_evaluate_path. Add rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname, and rtems_filesystem_prefix_separators. Remove rtems_filesystem_evaluate_parent. * libcsupport/src/base_fs.c, libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/chroot.c, libcsupport/src/fchdir.c, libcsupport/src/link.c, libcsupport/src/mount.c, libcsupport/src/open.c, libcsupport/src/privateenv.c, libcsupport/src/readlink.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c, libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c, libnetworking/lib/ftpfs.c: Add the length parameter to the eval call. * libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators, rtems_filesystem_dirname, rtems_filesystem_evaluate_relative_path. Add the length parameter to the eval call. * libcsupport/src/rmdir.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libcsupport/src/stat.c: Add the length parameter to the eval call. Set the device into the rdev field. * libcsupport/src/unlink.c: Find the parent pathloc then the node pathloc from that node. Remove the call to find the parent given the node pathloc. * libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the disk device number from the stat rdev field. * libfs/src/dosfs/msdos.h: Add the length parameter to the eval call. Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod handler. * libfs/src/dosfs/msdos_eval.c: Add the length parameter to the eval and token call. * libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the rmnod handler. * libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for only the allowed flags. Add the missing flags spec'ed in the POSIX standard. * libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the parent node. Currently ignored in the IMFS. * libfs/src/imfs/imfs_stat.c: Return the device number in the rdev field. * libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add the length parameter to the token call. * libfs/src/nfsclient/src/nfs.c: Add the length parameter to the eval call and parent node to the rmnod and unlink command. * libmisc/shell/internal.h: Remove the libc mounter decl to make public. * libmisc/shell/main_mount.c: Add support for hooking external mount support for new file systems. * libmisc/shell/shell.h: Add helper functions for the mount command.
2008-09-01Convert using "bool".Ralf Corsepius
2005-08-172005-08-17 Nickolay Semyonov <snob@oktetlabs.ru>Joel Sherrill
PR 744/filesystem * libcsupport/src/unlink.c, libfs/src/dosfs/msdos_eval.c: DOSFS did not support permissions on directories so the check performed by unlink would always fail. The unlink code was modified to support a not supported status being returned.
2004-04-18Remove stray white spaces.Ralf Corsepius
2004-04-15Remove stray white spaces.Ralf Corsepius
2003-11-252003-11-25 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett
PR 519/filesystem * include/rtems/libio_.h, src/eval.c, src/rmdir.c, src/unlink.c: Check write permissions in parent directory for file or directory delete
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* include/chain.h, include/clockdrv.h, include/console.h, include/iosupp.h, include/rtc.h, include/spurious.h, include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h, include/rtems/termiostypes.h, include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h, include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c, src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c, src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c, src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c, src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c, src/fcntl.c, src/fdatasync.c, src/fpathconf.c, src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c, src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c, src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c, src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c, src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c, src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c, src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c, src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c, src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c, src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c, src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c, src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c, src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for license changed.
2002-01-042002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one. * libc/cfsetispeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/cfsetospeed.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/chroot.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/closedir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fdatasync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fpathconf.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fstat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/fsync.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ftruncate.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/getdents.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ioctl.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/lseek.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/open.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/read.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/rmdir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/tcsetattr.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/telldir.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/ttyname_r.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/utime.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libc/write.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one.
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
2000-11-012000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
2000-09-282000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change.
1999-11-17Updated copyright notice.Joel Sherrill
1999-10-12Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill
places to make sure memory allocated for filesystem specifif nodes gets freed.
1999-10-12Added call to freenod to let each filesystem free its own internalJoel Sherrill
node used to manage file access.
1999-04-15Added reentrant versions.Joel Sherrill
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill
