Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
http://www.google-melange.com/gci/task/view/google/gci2012/8009205
* libcsupport/include/rtems/termiostypes.h,
libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_baudtable.c,
libcsupport/src/termios_num2baud.c,
libcsupport/src/termios_setinitialbaud.c: Added const qualifier to
baud associations. Fixed integer types.
* libcsupport/Makefile.am, libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_num2baud.c: Use RTEMS associations to
simplify code and make easier for coverage.
* libcsupport/src/termios_baudtable.c: New file.
* libcsupport/src/termios_baud2num.c:
Include rtems/termiostypes.h.
Rename termios_baud_to_number into rtems_termios_baud_to_number.
* libcsupport/src/termios_baud2num.c: B134 should return 134 not 135.
* libcsupport/src/termios_baud2index.c,
libcsupport/src/termios_setinitialbaud.c: New files.
