2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2010-08-03 | Remove redundant includes. | Ralf Corsepius | |
2010-08-02 | 2010-07-30 Bharath Suri <bharath.s.jois@gmail.com> | Joel Sherrill | |
PR 1645/cpukit * libcsupport/src/getuid.c: Moved setuid() routine to its own file. * libcsupport/src/setuid.c: New file with setuid() routine. * libcsupport/src/seteuid.c: New file with seteuid() routine. |
