The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
of this patch set.
http://www.google-melange.com/gci/task/view/google/gci2012/7992212
* libcsupport/src/putk.c: Remove useless variable initialization
pointed out by clang.
* include/rtems/bspIo.h, libcsupport/Makefile.am: Add putk().
* libcsupport/src/putk.c: New file.
