of this patch set.
* libcsupport/src/printk.c: Fix typo.
* libcsupport/Makefile.am, libcsupport/src/printk.c: Restructure to
make analysis and coverage easier. Now 100% covered.
* libcsupport/src/vprintk.c: New file.
* libcsupport/src/printk.c: Addresses can be larger than integers
so use long for %p formats.
* score/inline/rtems/score/address.inl: Offsets can be positive or
negative, so use int32_t. Also do math with intptr_t since there
are cases where the number of bits in an address do not equal the
number of bits in an integer.
* score/inline/rtems/score/heap.inl: Offsets can be positive or
* libcsupport/src/printk.c: Added width and padding for %s.
* libmisc/cpuuse/cpuusagereport.c: Support object names that are
strings longer than 4 chanracters.
* libcsupport/src/printk.c: Style.
* libcsupport/src/printk.c, score/src/objectget.c: Fix spacing.
* libcsupport/src/printk.c: Remove unnecessary comments.
* libcsupport/src/printk_plugin.c: New file.
include/rtems/bspIo.h, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuuse.h, libmisc/stackchk/check.c,
libmisc/stackchk/stackchk.h: rtems/include/rtems/rtems/ratemon.h,
rtems/src/ratemonreportstatistics.c: Added capability to specify
your own "printf" routine to various reporting functions. This
added an XXX_with_plugin as the underlying implementation for
+ rtems_rate_monotonic_report_statistics
+ rtems_stack_checker_report_usage
+ rtems_cpu_usage_report
As demonstration, the http netdemo can now print out stack
and cpu usage reports.
* libcsupport/src/printk.c: Add %p support.
PR 808/rtems_misc
* libcsupport/src/printk.c: Fix bug where specifying field width
crashed on pc386 BSP.
PR 498/rtems
* src/printk.c: RTEMS printk() does not support the %i format which is
used by a lot of driver/BSP etc. code. The trivial patch allows %i/%I
as an alias for %d/%D.
which have already obtained the va_list pointer.
* libc/stat.c: include <string.h>.
* libc/printk.c: Remove libcpu/cpu.h.
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h.
* include/Makefile.am: Remove bspIo.h.
* include/bspIo.h: Removed.
* libc/printk.c (printNum): Properly handle a maxwidth of 0
as reported by Nick Hennenfent <NICK.HENNENFENT@ROCHE.COM>.
