Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
http://www.google-melange.com/gci/task/view/google/gci2012/7992210
* libcsupport/src/posix_memalign.c: Remove warning.
* libcsupport/Makefile.am, libcsupport/include/rtems/malloc.h,
libcsupport/src/malloc_walk.c, libcsupport/src/posix_memalign.c,
libcsupport/src/realloc.c, score/src/heapwalk.c: Add rtems_memalign
as helper and as exposed nmemalign variant with few restrictions.
Also turn on compilation of _Heap_Walk but make forced calls to it
conditionally compiled. This should allow more flexibility to the
user as to run-time checking of the heap.
* libcsupport/src/rtems_memalign.c: New file.
libcsupport/src/free.c, libcsupport/src/malloc.c,
libcsupport/src/malloc_deferred.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_sbrk_helpers.c,
libcsupport/src/posix_memalign.c: Place all deferred free code and
place it in subroutines. Add plugin for dirtying allocated memory to
assist in debugging. Clean up comments and spacing as needed.
* libcsupport/src/malloc_dirtier.c: New file.
libcsupport/src/malloc_report_statistics_plugin.c,
libmisc/shell/shell.c, libmisc/shell/shell.h,
score/src/objectinitializeinformation.c: Add posix_memalign. Split
out management of deferred frees to subroutines.
* libcsupport/src/malloc_deferred.c, libcsupport/src/posix_memalign.c: New files.
