2016-12-23 | libio: Use CONSOLE_DEVICE_NAME | Sebastian Huber | |
2016-12-12 | Add INTERNAL_ERROR_LIBIO_STDERR_FD_OPEN_FAILED | Sebastian Huber | |
Update #2825. | |||
2016-12-12 | Add INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED | Sebastian Huber | |
Update #2825. | |||
2016-12-12 | libio: Ensure proper std file descriptors | Sebastian Huber | |
2016-02-03 | Use atexit() handler to close std file descriptors | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-04-26 | libcsupport: Rename open_dev_console() | Sebastian Huber | |
Rename open_dev_console() to rtems_libio_post_driver(). Rename rtems_libio_supp_helper to rtems_libio_post_driver_helper. | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2009-11-29 | Whitespace removal. | Ralf Corsepius | |
2009-11-09 | 2009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* libcsupport/src/open_dev_console.c: Use constant numbers to avoid overflow when shifting on 16-bit targets. | |||
2007-06-20 | 2007-06-20 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* libcsupport/Makefile.am: * libcsupport/src/open_dev_console.c: New file. |
