2015-10-26 | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2012-12-09 | libcsupport: Doxygen enhancement task #2 | Alex Ivanov | |
http://www.google-melange.com/gci/task/view/google/gci2012/8017203 | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2010-04-02 | #include <unistd.h>. | Ralf Corsepius | |
2009-09-30 | Rework autoconf defines. | Ralf Corsepius | |
2009-09-15 | Add __attribute__((unused)) to function arguments. | Ralf Corsepius | |
2009-05-06 | 2009-05-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* libcsupport/Makefile.am: * libcsupport/src/isatty_r.c: New file. |
