application visible API.
http://www.google-melange.com/gci/task/view/google/gci2012/7996208
* libcsupport/src/getlogin.c: Modify to use strncpy() on all paths.
* libcsupport/src/getlogin.c: Formatting. Add EFAULT.
* libcsupport/src/termios.c: Formatting.
PR 449/rtems:
* src/getegid.c: New (Copied from ../posix/src).
* src/geteuid.c: New (Copied from ../posix/src).
* src/getgid.c: New (Copied from ../posix/src).
* src/getgroups.c: New (Copied from ../posix/src).
* src/getlogin.c: New (Copied from ../posix/src).
* src/getpgrp.c: New (Copied from ../posix/src).
* src/getpid.c: New (Copied from ../posix/src).
* src/getppid.c: New (Copied from ../posix/src).
* src/getuid.c: New (Copied from ../posix/src).
* src/setpgid.c: New (Copied from ../posix/src).
* src/setsid.c: New (Copied from ../posix/src).
* src/no_posix: Remove getpid and _getpid_r.
