summaryrefslogtreecommitdiff
path: root/cpukit/libcsupport/src/assocremotebylocal.c (follow)
AgeCommit message (Collapse)Author
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2007-03-262007-03-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* libcsupport/src/assoc.c, libcsupport/src/libio.c, libcsupport/src/write.c: Split files to shrink minimum.exe. Hopefully this will not be deemed necessary to commit to the 4.7 branch. * libcsupport/src/assoclocalbyname.c, libcsupport/src/assoclocalbyremote.c, libcsupport/src/assoclocalbyremotebitfield.c, libcsupport/src/assocnamebylocal.c, libcsupport/src/assocnamebylocalbitfield.c, libcsupport/src/assocnamebyremote.c, libcsupport/src/assocnamebyremotebitfield.c, libcsupport/src/assocptrbylocal.c, libcsupport/src/assocptrbyname.c, libcsupport/src/assocptrbyremote.c, libcsupport/src/assocremotebylocal.c, libcsupport/src/assocremotebylocalbitfield.c, libcsupport/src/assocremotebyname.c, libcsupport/src/libio_init.c, libcsupport/src/write_r.c: New files.
