summaryrefslogtreecommitdiff
path: root/cpukit/libcsupport/src/assocnamebad.c (follow)
AgeCommit message (Collapse)Author
2015-10-26basdefs.h: Add and use RTEMS_UNUSEDSebastian Huber
2012-12-11libcsupport: Doxygen enhancement GCI task #6Alex Ivanov
http://www.google-melange.com/gci/task/view/google/gci2012/7992212
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-02-222012-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsépius
* libcsupport/src/assocnamebad.c: Add #define INSIDE_ASSOC.
2009-09-15Add __attribute__((unused)) to function arguments.Ralf Corsepius
2008-09-052008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill
* libcsupport/src/assocnamebad.c: Correct file name in message.
2007-03-132007-03-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* libcsupport/src/assocnamebad.c: Remove dead code. Use PRI* macros to fix warnings.
2004-04-15Remove stray white spaces.Ralf Corsepius
2004-03-232004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius
* libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types.
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
2000-11-012000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill
* include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files.
1999-05-27Split out the routine rtems_assoc_name_bad().Joel Sherrill
