* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c,
libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c,
libmisc/shell/shellconfig.h: Split malloc.c into multiple files with
one function per file. Also split out statistics into a separate file
which can be plugged in dynamically. Right now, it is always in. I
suspect that splitting the file removed more code than leaving
statistics in. I tinkered with malloc information command in the
shell. I resurrected the malloc arena code as malloc boundary. This
code is now compiled all the time even though it does not appear to
* libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c,
libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c,
libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c,
libcsupport/src/free.c, libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_get_statistics.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_report_statistics.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
libmisc/shell/main_perioduse.c: New files.
* posix/Makefile.am, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgettime.c,
posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c,
posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c,
posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c,
posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c,
posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c,
posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split
files into one function per file.
* posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c,
posix/src/aio_read.c, posix/src/aio_return.c,
posix/src/aio_suspend.c, posix/src/aio_write.c,
posix/src/lio_listio.c, posix/src/sched_getparam.c,
posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c,
posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c,
posix/src/sched_setparam.c, posix/src/sched_setscheduler.c,
posix/src/sched_yield.c: New files.
* posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed.
