2018-10-22 | Remove __assert() | Sebastian Huber | |
This function is provided by Newlib since 2000. Update #3409. | |||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | |
2013-09-22 | __assert.c: Fix missing prototype warnings | Joel Sherrill | |
2013-02-12 | score: Add and use rtems_assert_context | Sebastian Huber | |
2012-12-11 | libcsupport: Doxygen enhancement GCI task #6 | Alex Ivanov | |
http://www.google-melange.com/gci/task/view/google/gci2012/7992212 | |||
2012-11-15 | score: Add RTEMS_FATAL_SOURCE_ASSERT | Sebastian Huber | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2009-11-29 | Whitespace removal. | Ralf Corsepius | |
2009-09-30 | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* libcsupport/src/__assert.c: Rework autoconf defines. | |||
2009-03-11 | Conditionally build __assert(). | Ralf Corsepius | |
2008-01-09 | 2008-01-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | |
* libcsupport/src/__assert.c: Clean up and make __assert() call __assert_func(). | |||
2008-01-09 | 2008-01-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | |
* libcsupport/src/__assert.c: Newlib 1.16.0 adds __assert_func(). We need to have it also. | |||
2007-03-30 | 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | |
* libcsupport/src/__assert.c: Add HAVE_CONFIG_H. | |||
2007-03-28 | 2007-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | |
PR 1234/cpukit * libcsupport/Makefile.am: Provide printk() based implementation of __assert() to reduce dependencies in executables. * libcsupport/src/__assert.c: New file. |
