2012-11-02 | libblock: Block device transfer request API change | Sebastian Huber | |
Add and use rtems_blkdev_request_done(). Block device transfer requests must signal the completion status now with rtems_blkdev_request_done(). The return value of the block device IO control will be ignored for transfer requests. The first parameter of rtems_blkdev_request_cb is now the transfer request structure. Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to break third party drivers at compile time, otherwise this API change would result in runtime errors. | |||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||
2012-03-13 | libblock: Add optional free at delete request | Sebastian Huber | |
2010-03-28 | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | |
2010-02-18 | 2010-02-18 Chris Johns <chrisj@rtems.org> | Chris Johns | |
* libfs/src/rfs/rtems-rfs-bitmaps.c, libfs/src/rfs/rtems-rfs-bitmaps.h, libfs/src/rfs/rtems-rfs-bitmaps-ut.c, libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-block-pos.h, libfs/src/rfs/rtems-rfs-buffer-bdbuf.c, libfs/src/rfs/rtems-rfs-buffer.c, libfs/src/rfs/rtems-rfs-buffer-devio.c, libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h, libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h, libfs/src/rfs/rtems-rfs-dir-hash.c, libfs/src/rfs/rtems-rfs-dir-hash.h, libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h, libfs/src/rfs/rtems-rfs-file-system.c, libfs/src/rfs/rtems-rfs-file-system-fwd.h, libfs/src/rfs/rtems-rfs-file-system.h, libfs/src/rfs/rtems-rfs-format.c, libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c, libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h, libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h, libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h, libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h, libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems-dev.c, libfs/src/rfs/rtems-rfs-rtems-dir.c, libfs/src/rfs/rtems-rfs-rtems-file.c, libfs/src/rfs/rtems-rfs-rtems.h, libfs/src/rfs/rtems-rfs-rtems-utils.c, libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h, libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h: New. * Makefile.am, preinstall.am, libfs/Makefile.am, wrapup/Makefile.am: Updated with the RFS support. * libfs/README: Updated after 10 years. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk-driver.c: Updated to the new error reporting in libblock. * libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing the size in long mode. * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP to the forever behaviour of 4.9 with the ability to call BOOTP and control the process if required. | |||
2010-01-19 | libblock API update | Thomas Doerfler | |
2009-12-18 | Update for block device API change | Thomas Doerfler | |
2009-11-29 | Whitespace removal. | Ralf Corsepius | |
2009-10-20 | * libblock/include/rtems/diskdevs.h: Documentation. Added field to | Thomas Doerfler | |
rtems_disk_device. * libblock/include/rtems/blkdev.h: New request code RTEMS_BLKIO_DELETED. * libblock/src/diskdevs.c: Major rewrite. Changed the way disks are deleted. Disks will be now deleted if they are not in use or upon last release. The IO control handler will be invoked if a physical disk is deleted with the RTEMS_BLKIO_DELETED request code. Logical disks increase now the usage count of the associated physical disk. * libblock/include/rtems/ramdisk.h: Documentation. * libblock/src/ramdisk-driver.c: Compile trace support conditionally. | |||
2009-10-16 | restructuring of ramdisk code | Thomas Doerfler | |
