#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
* libblock/src/nvdisk-sram.c, libi2c/libi2c.c,
libmisc/shell/main_msdosfmt.c: Eliminate use of GNU old-style field
designator extension as recommended by clang.
* libblock/include/rtems/nvdisk.h, libblock/src/nvdisk-sram.c:
Use pointer arithmetic instead of int32_t arithmetic for 16bit
compatibility.
* libblock/src/nvdisk-sram.c: Add missing HAVE_CONFIG_H.
* libblock/include/rtems/nvdisk-sram.h,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
