summaryrefslogtreecommitdiff
path: root/cpukit/include/rtems/score/freechain.h (follow)
AgeCommit message (Collapse)Author
2020-02-12score: Add _Freechain_Extend()Sebastian Huber
Update #3835.
2020-02-12score: Add _Freechain_Pop()Sebastian Huber
Update #3835.
2020-02-12score: Add _Freechain_Is_empty()Sebastian Huber
Update #3835.
2019-05-13doxygen: score: adjust doc in freechain.h to doxygen guidelinesAndreas Dachsberger
Update #3706.
2019-04-04doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber
Update #3706
2018-12-14score: Static Objects_Information initializationSebastian Huber
Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
2018-01-25Remove make preinstallChris Johns
