summaryrefslogtreecommitdiff
path: root/cpukit/include/rtems/rtems/semmp.h (follow)
AgeCommit message (Collapse)Author
2020-01-02rtems: Fix MPCI initializationSebastian Huber
Update #2408.
2019-04-02doxygen: Restructured cpukit/include/rtems/rtemsAndreas Dachsberger
Update #3706.
2019-04-02doxygen: Reviewed cpukit/include/rtems/rtemsAndreas Dachsberger
Update #3706.
2019-02-28Remove explicit file names from @fileSebastian Huber
This makes the @file documentation independent of the actual file name. Update #3707.
2018-12-14score: Static Objects_Information initializationSebastian Huber
Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
2018-01-25Remove make preinstallChris Johns
