summaryrefslogtreecommitdiff
path: root/cpukit/include/rtems/libi2c.h (follow)
AgeCommit message (Collapse)Author
2019-04-04doxygen: Added some subgroups to API and IOAndreas Dachsberger
I2C library, Media Manager and Profiling Support Update #3706.
2018-01-25Remove make preinstallChris Johns
