2020-03-23 | conf: Improve evaluation of event recording opts | Sebastian Huber | |
Check for configuration errors earlier. Allow fatal dumps without the other extensions. Add some warnings. Update #3904. | |||
2020-03-18 | record: Add rtems_record_dump() | Sebastian Huber | |
Add rtems_record_dump_base64() and rtems_record_dump_base64_zlib(). Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB configuration options. Update #3904. | |||
2020-02-25 | config: Add <rtems/confdefs/extensions.h> | Sebastian Huber | |
Remove all comments and copyrightable content from the moved content. Use BSD-2-Clause license for new file. Update #3053. Update #3875. |
