summaryrefslogtreecommitdiff
path: root/cpukit/include/rtems/capture.h (follow)
AgeCommit message (Collapse)Author
2019-06-28score: Add and use _Thread_Get_unmapped_priority().Sebastian Huber
Add and use _Thread_Get_unmapped_real_priority().
2019-04-04doxygen: New API subgroup TracingAndreas Dachsberger
Update #3706.
2019-02-28Remove explicit file names from @fileSebastian Huber
This makes the @file documentation independent of the actual file name. Update #3707.
2018-07-19capture: Include missing header fileSebastian Huber
2018-03-07capture: Fix get priority methodsSebastian Huber
2018-01-25Remove make preinstallChris Johns
