summaryrefslogtreecommitdiff
path: root/cpukit/include/drvmgr (follow)
AgeCommit message (Collapse)Author
2018-12-27drvmgr: Improve LP64 compatibilitySebastian Huber
2018-10-09leon, spwtdp: Initial driver commitJavier Jalle
2018-04-20drvmgr: Remove bsp_driver_level_hook()Sebastian Huber
Use RTEMS_SYSINIT_ITEM() instead. Update #2408.
2018-01-25Remove make preinstallChris Johns
