2018-02-02 | spi: Use self-contained mutex | Sebastian Huber | |
Update #2843. | |||
2017-07-14 | posix/mmap: Add support for file handler and MAP_ANON | Kevin Kirspel | |
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r. Updated each file handler object to support the default mmap handler. Updated mmap() to call the mmap handler for MAP_SHARED. Added a mmap file handler for shm Added support for MAP_ANON in mmap(). Updates #2859 | |||
2016-09-16 | Add SPI bus framework | Alexander Krutwig | |
User API is compatible to Linux userspace API. New test libtests/spi01. Update #2776. |
