Update #3254.
Update #3599.
This Autoconf macro used cache variables which are not longer present.
Update #3409.
x86_64 is 64-bits and too new for the legacy stack to support.
epiphany is a small target and cannot compile the legacy (or new) stack.
Update #3433.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This fixes the legacy Makefile based build system which expects
RTEMS_API to be identical to the tool chain version.
Update #3220.
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
Next release will 5.1.0. Branch version after release will be 5.1.1.
Next master will be 6.0.0.
* Use #ifdefs for 32/64 bit code
* Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
* Move the code to a new shared riscv folder to be shared between riscv32 and riscv64
* Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv
Update #3109
closes #2443.
updates #2452.
Virtual machines with paravirtualization exist not only on x86.
for details.
This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* aclocal/check-smp.m4: Fix bogus log message.
PR 1729/cpukit
* configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S,
score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/context.h,
score/include/rtems/score/percpu.h, score/src/percpu.c,
score/src/thread.c, score/src/threadcreateidle.c: Add next step in
SMP support. This adds an allocated array of the Per_CPU structures
to support multiple cpus vs a single instance of the structure which
is still used if SMP support is disabled. Configuration support is
also added to explicitly enable or disable SMP. But SMP can only be
enabled for the CPUs which will support it initially -- SPARC and
i386. With the stub BSP support, a BSP can be run as a single core
SMP system from an RTEMS data structure standpoint.
* aclocal/check-smp.m4, aclocal/enable-smp.m4,
score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h,
score/src/smp.c, score/src/smplock.c: New files.
* aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
* aclocal/check-networking.m4, aclocal/check-posix.m4:
Rebase check on "$host".
* aclocal/check-func.m4: Linearize checks.
Add missing $2 to AC_CHECK_DECL.
* aclocal/check-func.m4: New.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/enable-itron.m4, aclocal/check-itron.m4: Replace
RTEMS_HAS_ITRON_API with enable_itron.
* aclocal/enable-itron.m4: Cosmetics.
* aclocal/check-networking.m4: Do NOT disable networking for the
avr and the m32c.
Rework CFLAGS setup.
* aclocal/sysv-ipc.m4: Remove (unused).
