summaryrefslogtreecommitdiff
path: root/config-ml.in (follow)
AgeCommit message (Collapse)Author
2008-12-312008-12-31 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius
* config-ml.in: Comment out arm/thumb exception (Add arm/thumb multilib).
2006-08-092006-08-09 Kolja Waschk <waschk@telos.de>Joel Sherrill
* config-ml.in: New port to Altera NIOS II.
2004-08-182004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius
PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'.
2003-10-232003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* config-ml.in: Don't built multilib variant normal (-mn) for h8300-*-rtems*.
2003-07-152003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* config-ml.in: Partial sync with gcc-3.4's config-ml.in. Add "autoconf-2.5x unquoting" hack.
2003-03-25Merger from rtems-4-6-branch.Ralf Corsepius
2002-07-062002-07-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius
* config-ml.in: Imported from gcc-3.1. Change to match c/src/config-ml.in.
2002-07-06Initial revisionRalf Corsepius
