line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
* Makefile.am: Remove depend-am.
* Makefile.am: Cosmetics.
* configure.ac: Add support for --disable-rtemsbsp. Cosmetics.
* Makefile.am: Remove RTEMS_BSP-subdir rule.
* configure.ac: Let AC_CONFIG_FILES(Makefile..) append explictit
rules for RTEMS_BSP-subdirs.
* Makefile.am: Use mkdir_p instead of mkinstalldirs.
* configure.ac: Cosmetics.
* Makefile.am: Don't explictly invoke $MAKE preinstall.
* Makefile.am: Use mkinstalldirs instead of mkdir.
* Makefile.am: Remove make from SUBDIRS.
* configure.ac: Remove make from CONFIG_SUBDIRS, cosmetics.
* Makefile.am: Switch to macros/, reflect new configure.in,
* Makefile.am: Make sure $SHELL inside of Makefiles does not get
propagated to the BSP-subdirectories if a user specified CONFIG_SHELL.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
