Update #3678.
This avoids a dependency to errno in device driver code.
Reduce copy and paste.
When the CCSDS/CCITT CRC-16 and 16-bit ISO-checksum logic is available in
GRSPW2, the DCRCT field is used to determine how to generate the CRC/checksum
code. grspw_hw_sup has been extended with the field ccsds_crc
It enabled promiscous mode or sets the multicast filter according
to the configuration and parameters to ioctl(SIOCSIFFLAGS),
ioctl(SIOCADDMULTI) and ioctl(SIOCDELMULTI).
On SIOCADDMULTI/SIOCDELMULTI requests the greth ioctl calls the
Ethernet helper functions ether_addmulti()/ether_delmulti() which
tells the greth driver when its required to update the MAC multicast
filtering.
The interface notifies support for multicast by setting IFF_MULTICAST.
The GRETH has two registers which contains a bit-mask of allowed MAC
addresses. The incomming MAC address is CRC:ed and the CRC is used as
an index into the bit-mask to determine to allow or drop the frame.
This reduces the link-time dependencies and avoids copy-and-paste.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
